- 11 Jun 2013
Sold!
...and as reliable as your average uk public transport provider. Go for the Logitech is my recommendation after using both manufacturers product.T300 rs gt, belt driven not cogs, smoother ffb, interchangeable rims.
That's a bit like saying buy a Nissan Micra instead of a ferrari because ferraris break down more often. Anyway it's not an issue if you buy from a decent retailer with a good returns policy....and as reliable as your average uk public transport provider. Go for the Logitech is my recommendation after using both manufacturers product.
I got my first ffb racing wheel on Tuesday and although I'm utter poop with a wheel compared to a pad I'm having so much more funI'm much much slower with a wheel but could never go back to pad now, even coming last or back of the grid I'm enjoying it more than I did with a pad and hopefully I will get as good with a wheel after lots of practice
that's good to hearYou do get used to it, I was the same.
Also for anyone wanting more immersion, try the shakeit ffb pedal mod, for around a total of £15 it's a no brainer and amazing!
I could t say weather both are usable but set up is a breeze and takes 45minutes tops including installing the motors. A breeze!I have zero technical knowledge, and I have simvibe bass shakers in chassis mode already...how easy is this to set up? I've read you can't use both.
