I need a bit of help.
So I will be using 120mm fans, especially 2 for a Corsair H100i cooler.
2 things to keep in mind, the wood is 19mm thick, and the fans are 25mm thick.
What I was thinking is cutting a hole in the wood to fit the 2 fans in snug.
And then the cooler screws into it.
But I need some way to mount it to the desk.
What I was thinking is trying to get some 2mm thick aluminum cut out in the middle to fit the 120mm fans.
With little pop outs or rounded corners to screw the fan into.
I have done a really rough drawing in paint.
Basically the black is a aluminum cut out, that I will screw flat into the desk.
And then the fans into those corners, and through into a radiator.
But does anyone know where I can get something like this?
