Some more little updates.
Worked a bit more on the desk.
Close cuts to the legs, to make it more ergonomic.
You can see the drop where the gaming PC will go, and the start of the draw units.
Getting everything fixed up nice and tight.
Some nice fitting screws.
Tools of the trade
Making hole first
Nice shaping
And then screwing in.
End result
Working on the draw units
Fixing it nice and tight
Testing draw fitting, yes technically its upside down but just checking it fits
And another one for good measure
The desk is now the right way up, finally
Will finish off the draws, and get the runners installed and done.
Then back to my house for test fittings of the PC components.
That will be at some point next week hopefully.
