Project Ethos & Cube - Desk Awesomeness
So bit of an update...
Did some work yesterday afternoon.
Decided to take apart the radiators and spray the shells white.
So shells without the cores:
End bits sanded down:
Sanding away:
Ends and shells all sanded down.
Looks quite nice with the silver edges :D
Did a coat of primer, but it was very windy so had some bubbles and some thick bits. So decided to sand it down again.
Primer sprayed in garage = no wind!
Looking better:
Liking it in white!
Started to do some more work on the desk:
All standing:
Back is on, hiding the insides away:
Looks nice with the back on:
Inside lip cut down, and from the inside with the back on:
Cutting the draws down to fit the new design:
Showing what it looks like from under the floor looking up the desk's skirt.
Guess the back really does cover it nicely, you can just start to see the insides:
Back for where the UPS will be standing upright:
Back board joining onto desk:
Draws being fitted, checking size and spacing:
Back to do another coat of primer:
After its dried for awhile:
Looks really nice in white:
Sexy!
Some Moar:
Quite like it with the grainy look, of the black still slightly coming through:
Now, I just need to let the primer fully dry, and then I will spray it Matt White.
Did a stain on a cut off piece of wood to check it matches my TV Unit at home. (I can report it is almost a perfect match)
Wow. I've not been checking in on this - saving it for a quiet moment, such as now. I'm absolutely stunned by your workmanship and execution of the concept. You sir, are an inspiration!
Oh man do I have an update for you guys.
My mobo trays are finally cut and ready :)
I will get them within the next few days, but these are the pics from the creator :)
Also remember that Cube will be a server and a half height machine, and Ethos will be for my gaming so slightly larger to accommodate bigger that ATX size, eg the Rampage series of boards.
And lastly its just a test fitting with a dummy board.
*Warning, there are a lot of pics*
this, this, is what brilliance should be! The craftsmanship of both the desk and the mobo tray are superior. I like the fact that you even list the joints used! What made you decide on such joint? I'm guessing for strength?
