PROJECT: MAGNUS AQUA DOMUS!
I may have dropped them an email :rolleyes:
No reply yet though I expect they are rather busy with their new following.
The alphacool plate they did on their build log really sold me :D
They are designed for wc, its a no brainer if you want sff and a fair amount of radiator :)
Quite glad they showed up, a breath of fresh air in a quite drab case market.
i reckon by the time i go for water they will have expanded their range a bit. i know they want to grow but its good that they are a small company in a way as it means its easier for them to listen to their market directly and offer exactly what people want. i think thats why everyone is loving their small wc cases.
sorry for off topic.
you got any oc done on the gpus yet?
Got 1250/1700 fairly easily the other night :)
Modded trixx is being a pita so once I have the memory sorted I'll try flashing the asus bios to get 1.4v from gpu tweak :)
i hear stories on here that gpu tweak is horrible and full of bugs?
not tried it myself personally. i just oc'ed using CCC to get a healthy 1100/1550
does the power slider do anything in ccc? i just stuck it on 20%
Yep moving power limit slider to 20% increases TDP of card so more voltage can be used, this is why it is essential for overclocking :)
Trixx can be good, many use it as it has extended voltage ranges for ref 7970's, sometimes it works sometimes it just flakes out and causes a driver crash! I'll have a better clock at the weekend, still getting my sammy green issues sorted.
Yep if over volting push the slider to +20%
With trixx I got lower benchmark scores in heaven valley for some reason, so using CCC for OC and trixx for custom fan profile
Ah well, I need to get this loop open next weekend and get some bits sorted, just had an hour on Hitman Absolution, temps spiked up to 50c on each GPU, I think I have a flow issue somewhere :(
I can't actually see any fluid moving, if it is, its moving very very slowly.
Yeah, I'm not overly confident the d5 is either working to its full potential or coping with the loop, perhaps time to consider dual loops.
Is the pump on number 5 speed setting? Forgot I turned mine down when I was setting the system up and was wondering why it was a bit poor :)
Yep, they do a full plexi version that looks epic with coloured fluid, shame they are quite hard to source in the UK and ain't cheap :(
Might just get another alphacool plexi top and glue em together :p
Might drop a little food colouring in my res later today to see just how bad the flow is.
no there not, think there about £100 by time your done, ouch!!
Food colouring!!, not harmfull in any way then??
For future can you not get a flow meter or are they just on the aquaero's??
edit: is CS closed at weekends???
