- 1 Sep 2005
- Scottish Highlands
Well its been an eventfull time since last update. I bought a cheap PCI-E card to test the PCI-E sockets, and it turned out that it was indeed the mobo that was borked. So I took the plunge and bought;
P5B deluxe
E6400
2Gb OCZ
7900GS
Put it all in, and it ran nicely. Managed to get a nice stable clock up to 3.7Ghz But then last night I was on the computer when all of a sudden the screen goes black. I turn to my side to see white smoke pouring out of the computer, so i quickly pull out all the powr cables. I stripped it all down, and it turns out the Phase evap head back plate had shorted the back of the mobo. the backplate is basically a metal plate with the relevant screw holes in, with a layer of neoprene and a heaterplate on the inside. I think what had happened, is that the neoprene was too thin, and I had tightned the whole thing too much, causing two of the solder points on the back of the mobo to pierce the neoprene and touch the metal backplate. A small charge then ran through this backplate, heating one of the bolts which in turn heated the mobo resulting in a dramatic scorch mark and a dead mobo.
Damn this rig is turning out to be expensive. and to top it off, it looks like OCUK don't sell the P5B deluxe anymore.
P5B deluxe
E6400
2Gb OCZ
7900GS
Did you scream or anything?
