okimanoob said:I have a spare V2000B+ Side Panel if you still need one ?
Yewen said:Considering your other projects can't wait to see how this ends up when its all done.
messiah khan said:But since I was going to get a custom phase unit built, I also wanted it to be something special.
Mr-White said:nice, you built one before ? need more specs, gas, evap blocks, compressor HP etc etc ???
MW
On the 150w tester it's doing well though. I used a 402a blend as I liked the setup on the condensor cooling and it's been great. -63 at no load, and -42 on 150w after about 1/2 hour so far. Compressor staying fairly cool, and no problems with it at all.
I've been using it with the tester for a while now, and while it's still no right at lower loads, it seems to be about right for 210w. I backed off the charge just a little and it fell off at about 210w, -33c.
okimanoob said:pm sent via msn
okimanoob said:The msn mail item I sent to your address in trust has been returned undelivered
Cheersorderoftheflame said:Looking good![]()
CheersJustin said:Wicked, your mods always make me jealous![]()
Drazic said:You sure your rad is not going make mounting the evap a pain in the bum? I had problems with a 38mm fan in the same place with my Kayl head.
Went and put a PA120.3 in the top just for the NB
Drazic said:OO nice...wouldn't mind one of them in my V2000B!!
The hose will be fine, the 2 80mm's you go them sucking in or out?
If the rad doesn't clear, fit roof mount it but interanly!!
You also need a PSU! Nice PC+P 510 will do the job and exactly what i have going spear currently
