- 28 Oct 2005
- Stoke-on-Trent
Looking forward to the pics!
ooo.. harshmessiah khan said:In the same place as the Android updates.![]()
ChoÞÞer said:ooo.. harsh![]()
messiah khan said:Gray also decided to use an unseen controller due to certain issues with the Golden Froster controllers.
Sipha said:What are those issues matey, just out of interest ?
messiah khan said:No, it just means that depending on how it was wired up, you might get gobbldegook more often. Basically if the cabling has been routed near other power cables etc, without being shielded properly then you might find that the controller throws up rubbish from time to time. By no means is it a bad controller, its just at the time of building mine, I think Gray had seen a few dodgy ones play up, so he decided to try out the Unseen controller instead.
whitedragon said:nice im imprest and i dont say that often plus i like that case
