I'm trying to start thinking about 'what next?' as things have stalled a bit for the moment. I've got a DDC pump with a nice Barrow top (the volute looks particularly good) and heatsink and I have a Bitspower Z-Tube res. Trouble is that the res is really too small for the build. Yeah, I know but I can't help it!
Now I believe there is a longer Z-Tube on offer in the near future....but I've started thinking by now....or rather over-thinking...and that's a dangerous thing!
I started idly surfing and browsing the reservoirs on offer and decided two things. It needs to be square rather than round and it needs to have the pump integrated into the bottom - both for aesthetics, you understand. I've built things with bits zip-tied together in the past and that's not what I want to do this time. The one I particularly like the look of was a Swiftech Maelstrom that has a (rounded) square tube but it's no longer available and has been replaced by a V2 that no longer has that. Also, like most others of this design, it takes a D5 pump...and that's not what I have. I also decided that I didn't want to throw a hundred-odd quid at the problem to make it go away
So instead I have complicated my life in a somewhat apt self-inflicted way. I've ordered a 55 x 4.5 x 200mm borosilicate tube from a Chinese lab supplier and I reckon that I ought to be able to knock this together:
It'll need the top of the pump-top skimming down by about 1mm to get rid of the Barrow logo sticker recess. Then an o-ring groove milled in the top for the tube to seal directly against. Ditto for the top that will need making out of acrylic or Delrin - I'm favouring the latter as it doesn't need to be transparent. The upright struts will screw in from top and bottom to compress the o-rings against the ends of the tube. That will mean making the existing threaded holes in the pump-top into through-holes and finding some much longer screws that will then hold heatsink, pump and top together by pulling them to the struts and squashing them against the base of the tube.
I'm hoping the RGB light strip in the pump-top might also illuminate the res....but we'll have to see. It's ARGB so I don't yet have anything to power it with. I have my eye on a Jonsbo test controller for a whole £4 but I need to make that order up to something that isn't taking advantage of OCUK's good will. I might have to swallow my pride and buy some fans. I didn't want to as I have a literal box-load of them. Trouble is that the only ones that match are silver and light up green....and I'm not sure I can carry green and purple in this build!
