Santa pod is most certainly on the cards! As are a few track days I think.
The shed is the landlords, kinda lucky to have this at the bottom of the garden really!
This is still being worked on, just little things happening and moving/altering/finishing a few things ready for wiring, I want as much as I can in place before I start wiring.
Got the number plate mount sorted though, will eventually get all the parts of the undertray welded together.
The clocks bracket got made too,
Thats been cut and the final bit of welding is being done this week along with the new rad mount, made one out of stainless that has the fuel pump mounted on it and the fan is also mounted to it as well. Another thing I've recently bought, a mega powerfull 5'5'' fan!
Also had a crash course in turning, made a bush for the AIT sensor, this will now sit in the plenum rather than in the silicone hose before it, just couldn't get anything to fit.
Not bad for my first turned piece eh?
Also turned a couple of hats for the ends of the throttle cables, the ones that came in the kit (right) just didn't fit with the Busa switch gear so I turned a couple up. These literally just finish the the ends of the cable off and sit inside a plastic adjuster.
Should have some more pics of finished pieces soon!
