Im crap at updating this thread!
I have an engine in the bike now, standard 1100 W with a 1.5mm spacer plate under the barrels, if my math is correct it should take the comp ratio to 9.1:1.
The engine is supposed to be a good low milage one but there are signs that its dropped a valve at some point probably farily recently, dinks in the piston top and head etc, the bore looks ok and the valves look ok too but im not holding out much hope of this one lasting that long!
Should get me up and running though and be suitable to test if my set up works or not.
So im starting to build the bike up to a stage where it'll run, current issue is fitting the plenum, with the injectors in I now can't put a bolt through the top holes as you can see here
I'll have to put studs in the head, if I do that though I cant fit the plenum on with the fuel rail attatched so I have to take it off, but it wont fit on with the plenum in place as the frame is in the way!
I may have to slot the top holes so the whole assembly will slide on sideways.
I also need to skim the flanges on the plenum as they've warped quite a bit with all the welding, times like these is when Im glad there's a mill in the shed!
I need to have a look in to stick coils, Ive recently fitted one to the DR and its solved quite a few starting problems, it also likes the wet better now!
There isn't a lot of room above cylinder 1 and 4 as the frame goes over them but if I can find something to fit in then it could save a few problems down the line.
Once Ive sorted that problem im getting real close to making the loom, I have a load of cable here ready and a massive wedge of paper on how to wire the ECU etc!
Hopefully I may get this running in the new year!
