- 24 Apr 2012
- Carlow, Ireland
my flushing marathon. well wife is the least impressed person in the world at the moment.
If that doesn't do it, nothing will!
so what do you guys recommend. 420mm and 240mm will just be enough to keep cpu and 2x gpus happy? shall i drop the additional 120mm rad?
As a hand-rule you can cool a single chip with 120*120mm radiator (with no overclock). You would need 360 for that. The 420 already has more surface area and you have a 240 on top of that. You should be good.
i have spoken to Phanteks and they are going to send me a new front panel Led strip. so case issue is hopefully sorted![]()
Ah good stuff, hopefully it's a straight forward swap!
yes looked at it but it doesn't say specifically if dye stains can be removed. I have already put crazy things through rads like washing powder to carpet cleaner. and nothing changed. I am in giving up mode on this.
New rad time.![]()
It might be worth dropping Mike from Mayhem's an e-mail and see what he says.
It's always possible he can help.
Great looking build, can't wait to see how it turns out.
If you're looking at new rads the new EK rads seem to do really well in reviews.
Just a quick update that I ordered a Hardware Labs GTX 360 Rad.
Good choice, I too have a 360mm in the top of the case (Same layout as yours). Did you have any issues removing the drive cages as mine were stuck in good
Excellent work![]()
na mate. drive cages came out with relative easy. But it needed a bit of working around the 5.25" cage (which is not suppose to come out anyway). But now I do not have anywhere to mount two HDD's. There are two mounting points for SSD in cable management area at the back. Now thinking of how to securely install HDD's. Also I have to live without the BD-RW and use an external drive when necessary.
Plus I am using push/pull on both rads. This makes space really tight in front for a hdd cage to be re-installed. And I am going to use any remaining space between the rad and the psu for two pumps.
