- 22 Jul 2015
- Aberdeen
I removed the 5.25" cage from my case as well. To be honest I like the idea of the SSD's being out of sight in the back as it will make the cables look cleaner. As for the HDD would they also mount in the back? I'm surprised you are still using optical drives, only time I use them is when installing games over 20GB![]()
actually don't use it much. bought this bluray writer when they pretty much came out a few years ago. Occasionally for an OS install if that's required. so thats ok if it doesnt go back in now.
No there isn't room available in the back for HDD's. They are simply too deep to put on the side panel properly when installed. I may install them vertically just next to rad.
