Permabanned
- 12 Jan 2021
Can you name and Shame them
Read through this thread, plenty have already.Can you name and Shame them
Well it happened with the MM vouchers last week as well, so let's not put this solely down to being on the public side.We thought this would happen, but we made a promise to try and so we did.
Listed 4 hours agohttps://www.facebook.com/marketplace/item/156673399660743/?ref=facebook_story_share
Luke Bartlett of Uckfield
Listed 4 hours ago
Listed 3 hours ago - both before this deal even went live
2 on Shpock appeared @ScottiB @Space Monkey
Junaid A
B26 Birmingham
https://www.shpock.com/en-gb/i/YGGnOSXuY1nXQFSP/sapphire-amd-radeon-rx-6700xt-nitro-12gb-gpu
Jamie B
RH2 Banstead
https://www.shpock.com/en-gb/i/YGG-lAdlLVZoTCTW/sapphire-amd-radeon-rx-6700-xt-nitro-12gb-gr
Listed 4 hours ago
It will be less likely to happen, you lose more than just your account, you lose the ability to use MM, your account and would have to start over with another 1000 posts and 6 months wait. Unless you're just one of those that don't give a rats backside.Well it happened with the MM vouchers last week as well, so let's not put this solely down to being on the public side.
Nope.
As I've said before, the problems that we have with overselling are due to the delayed communication between the website and our internal software. The vouchers are counted website side so, no matter how long it takes for our system to answer back, the website shouldn't allow more than we want it to.
Thankfully the new website that we are working on should have website side stock allocation.
Good spot!
Ahhh man both good points, I was searching for new today didn't check times on these two, still could be worth looking intoListed 4 hours ago
Could a new mm be temporarily made, one with fewer posts?
So now if it goes back to the MM, the whiners will probably resurface..
MM is worth way more than just a quick buck with some of the stuff that gets listed there by members for a reasonable price. You'd have to be a literal idiot to buy to sell on.It will be less likely to happen, you lose more than just your account, you lose the ability to use MM, your account and would have to start over with another 1000 posts and 6 months wait. Unless you're just one of those that don't give a rats backside.
