Panyan said:would it be safer using a molex input for the power rather than running multiple fans off one header
Not safer as such as the circuit can't draw much more than about 0.4A but I have already planned to remove the two wires from the PWM connector and get power from a Molex as an option.
I'm also thinking about designing a second partner circuit that will drive fans without RPM feedback and this could then run off the Molex and you could perhaps run loads of 3 pin fans off that, still using the same PWm signal. I have the design ready, just need to breadboard it up. I could make a distribution board for it too, something like the one you might have seen in my videos. One one side the PWM to DC circuit and on the other a PWM to 12v circuit for the rest of your fans.
Every single fan controlled by your CPU temperature PWM curve. Sound interesting?
Panyan said:ive heard lots of reports that pwm fans can click when run at under 12v (or not run on pwm mode), especially akasa apaches
This shouldn't be the case as 4 pin and 3 pin fans don't really differ mechanically, just electronically, however it's not wholly relevant here as we won't be using 4 pin fans on the circuit.
Interesting though as I have a Apache and might whip it off and test that out. Mind you sometimes I notice it clicking even when running under PWM control. I knew I shouldn't have believed the Akasa hype, when I knew they were a bit pants from fans I've had from them before.
keep it up Tealc!
