Ok.
I brought some fans, some PWM converters, a multimeter and an 0.8A LED strip into the the house for connecting up to my PC and running some final tests.
Seeing as I like graphs and data I thought I'd show how Panyan's reacted to PWM duty cycle through it's range with a load of 0.35A.
A nice smooth transition down from slightly below top speed, down to slow speeds. Speed is consistent too. Only varies by an RPM or two once it's set.
On high setting it's quite different as high is engineered to cope with a fan or two extra.
It runs at full whack and begins to slow down very slowly as duyty cycle drops away, then eventually it drops away. I guess this would be useful if you liked a bit of top end speed early on in the duty cycle range.
The converter has been running now for about an hour up and down and it's warm but not too bad. Ideally the heatsink would be exposed to air but it's using the heatshrink to dissipate it's heat instead.
As I remove the PWM connection the fans instantly speed up to maximum as designed.
I'm pretty happy with that.
Onto the LED strip dimmer. This works quite well but does go pretty dim at sub 30% duty cycle. It's hard to say how this will be with single colour LED strip though. It could do with a bit of a boost at the lower end. Not quite sure how to do that at the moment but will look into it. Maybe some sort of voltage divider coming in with the PWM signal to boost it from 1v average at 20% to 2v or something.
Next up Resident's.
