Ok So I have mine running now with 2 Corsair SP120 Performance Edition mounted on my Matterhorn Pure.
After an initial problem which turned out to be a fail-safe option in my BIOS it's working spot on.
Even though the fans are running 300rpm more than the original Alpenfohn single fan, it's quieter. I've adjusted my PWM control using ET6 and using the medium setting on the adaptor it's settled at a little over 1100rpm @ 30°C (Ambient: 24.1°C). Bear in mind that these fans will max at almost 2400rpm @ 12v.
I haven't tried a stress test yet but I will do soon, but I do know the medium setting on the adaptor with PWM @ 100% duty cycle pushes the fans to just under 2300rpm which is almost max speed at which point my PC sounds like a TurboProp winding up for takeoff.
Tealc - I know I quoted different figures in my email earlier, I've tweaked ET6 some more since then
I would like to openly thank Tealc for taking the time to design and build the adaptor and for all the support he gave when I couldn't get it to work correctly, which again I will state was an issue with my BIOS settings and not the adaptor.
Ignore the cheap generic exhaust fan, it's temporary. It's getting replaced with an AF120 soon
