The 1080 is for those who want the fastest card and don't mind paying for it, the 1070 is a sweet upgrade and at a reasonable price, the 480 will be for those on older systems or those who want to get into PC gaming and at entry level.
Features? what features? you tell me, you're the one who made the argument, what features does the RX 480 have that the 970 or 390 does not? what features are they which make it a similar value at similar performance?
He also said that he never actually tested it. He just plugged it in and turned it on pretty much. So he is going on expectation and not experience.
Actually I have not argued with anyone but according to you people may as well buy the R390 instead.
Should people ignore Display Port 1.3 features for a start, new voltage over clocking possibilities. All the benefits of less heat/power draw and quieter operation? Do yourself a favour stop giving people poor advice and LETS JUST WAIT to see how reviews show exactly how the card performs.
Does anyone know if theres Xfire Support for
Elder Scrolls Online
Diablo 3
The Division
WoW
Grim Dawn
These are the only games i play pretty much, they all run fine on my 290, although Division gives it a bit of a hammering now, and im moving to 1440p from 1080p, so want more grunt...
If Xfire works on those games i will prob go down the Xfire 480 route.
Edited to add: Hang on just found this list http://amdcrossfire.wikia.com/wiki/Crossfire_Game_Compatibility_List
Err a 1070/80 is Nvidaia midrange part too..................................
Genuine question here, what did you guys realistically expect from a $199.99 graphics card?
1080 is the most expensive card of its generation, the most powerful card and the latest current architecture.
It's not a mid-range part and your posts don't make it so.
Should have just stuck the Nano cooler on it![]()
Or the 970 until Nvidia release the 1060 which would no doubt be faster than a 980 and there in the 480.
There is no point to the 480.
Elder Scrolls Online - yes, but you need to install a custom xfire profile last I recall
Diablo 3 - no (but don't think you would need to with a single 480...)
The Division - yes, but with some flickering issues
WoW - yes
Grim Dawn - yes, but unoptimized
That official AMD support list won't give you the full story, unfortunately. Honestly, after much experience with Crossfire (and SLI) every generation over the past 12+ years, I'd suggest sticking with the fastest singly card you can get. My advice is unless the Crossfire config is 50% faster and that 50% is needed for you to run your games comfortably than a single comparably-priced card, stay away from multi-GPU.
I'd say the GTX x80 and x70 parts are mid range, seeing as a Titan and a x80Ti are pretty much a given in each generation now.
Should have just made cheaper die shrunk nano's with 8gb gddr would have sold like hotcakes.
