MikeTimbers said:What ambient temperature?
What kind of rad and fan?
What flowrate from the pump?
What Vcore?
AndyOcUK said:FX57 @ 3.2GHz
38 Degrees after 3 hours of prime 95.
AndyOcUK said:Ambient room temp is around 39 at the moment in this weather
AndyOcUK said:Come on guys - approximately!!!!
This is my day job. I have a house and a Mrs and a lot better things to do with my time than staring at a thermometer in the spare bedroom!!
Sounds like someone needs a night out! lol![]()
Read carefully - last quote says AROUND 39 degrees
AndyOcUK
OcUK tech
AndyOcUK said:How do you know. Have you seen my rig?
weescott said:I dont have to! You can not have water temps less than at a guess 12c over ambient for your rig. Add the overclock and the temperatures you have given are well out.
I would holeheartedly agree with that, idle temps are slightly less but load temps are considerably lower and for the GFX card as well.MikeTimbers said:Cool'N'Quiet changes the multi and voltage according to load requirements. I'm talking about the cpu going into a HLT state which is completely different. Your idle temps will be lower but not by as much as your load temps, I suspect.
AndyOcUK said:My CPU (@3.2GHz) runs at 38 - 39 degrees under load at the moment. FACT.
I know my stuff - the clue is in the job title. I wouldn't work here if I didn't know what I was on about.
Check this thread out, I know my stuff:
http://forums.overclockers.co.uk/showthread.php?t=17580432
Also, I don't really value the opinion of anyone who make rash comments about a rig they've never been in the same room as before. You don't know about the second stage reservoir cooled by a 120mm fan from the front do you? You don't know that the arse end of the radiator pratically hangs out of the window on a north facing wall of the house that gets no sun do you? You don't know where or how the tube is routed do you? You don't know weather I'm clocking with a multiplier or FSB or both do you? You don't know what pump pressure is set to do you? You don't have an accurate reading of the temperature of my room do you? You don't even know if its water I've got in the tubes. In fact, you KNOW NOTHING yet persist in trying to belittle and **** people off to bolster your own unfounded self importance. A point further reinforced by your own childish sig. "How far will my CPU clock? Clock it and see Noob!"
As the above link shows, we reached No. 4 on the custom pc benchmarks with an aircooled rig when the top 20 were on phase change promeitia, vapochill/ waterchill systems. I have nothing to prove to you or anyone else. I know what I'm capable of and I know you are out of order preaching nonsense abouta system you have no facts about or have never even seen.
AndyOcUK
OcUK Tech Manager
easyrider said:Please can we keep my thread on track...?
I get my Kit delivered today and I am sure I will run into some problems...questions help etc...
As its my first attempt at water cooling.
I appreciate everyones comments and I have learnt a lot already but I would appreciate for the thread to be kept on track![]()
Thanks
Easy
