Any tips for best settings, default frame rate is low!
1080ti, 3440*1440.
DX12 or Vulcan?
Great settings on page 116. That is if we are on the same page... If you get what we I meanAny tips for best settings, default frame rate is low!
1080ti, 3440*1440.
DX12 or Vulcan?
Thanks! I have a GTX 1070. I'm currently using these settings:
Edit: @imginy @physichull @Strudders I had to reupload the video, so the ones listed in your replies are no longer working.![]()
1080ti, 3440*1440.
DX12 or Vulcan?
Running this same card and have a constant 60 FPS at ultra settings using DX12 , turn of GRASS ! its a killer and is not needed and doesn't make much difference to the game look , also make sure Water is on Medium settings you dont need that on ultra , Everything else can pretty much go on max settings , TAA Max ect.
disagree per my above comments.
