The Moonshiners Online DLC is now downloading....
It's a big one7.62GB
Might drop into Online soon and see what it is like....
I don't think many of us would be using the companion app as I don't believe it communicates with the PC version.I'm on console but it seems a bit more active in here, so I'll shoot.
Can anyone get the companion app to work on Android, specifically a P3? I install the app, allow permissions before it then just crashes
I did use it briefly when I played on the Xbox One about 8 months back but it crashed quite frequently back then on my Galaxy S7 as well.
I changed controller preset to standardFPS2 which assigns RUN action on right bumber instead of A. This helped a lot with playability for me. And on PC it is also possible to disable auto aim and still land shots thanks to smooth 60fps aiming.It's it possible to customise the controller? I find that holding A to travel is preventing me from panning with the right stick.
Do you mean playing solo in a private server where no other players can join or playing in a public server with other people but keeping to yourself?Can online be done as a solo player?
If the first option, I don't think they currently have private lobbies for you to play on your own but some missions will put you into a temporary private session. Haven't played online for a little bit though so that may have changed with recent updates, someone else may be able to confirm.
If it's the other type of solo play, you'll have more of a grind doing everything on your own compared to other people but should be fine to play as a solo player online. I've found most people leave me alone when I want to just go about my own business so you can still have fun without joining up with a posse.
Online seems to be a bit more stable now. Is there another patch in the pipeline?
Go to the map and double click your destination so you get a highlighted route then go to cinematic view and you will automatically follow the route. It's not insta travel but you can set your horse to gallop and sit back and watch the scenery as you auto travel to your destination.
Is anyone having trouble launching this tonight? It can't get signed in and there's no access to the game.
