Couple of more parcels arrived, first was dispatched from China on Monday and arrived today, pretty impressive.
Then this arrived
It weighs 51kg
![Box-from-Chins.jpg](https://i.postimg.cc/cCWY1kd6/Box-from-Chins.jpg)
Then this arrived
![Quattro-on-pallet.jpg](https://i.postimg.cc/prgdXpfC/Quattro-on-pallet.jpg)
It weighs 51kg
![Quattro-in-car.jpg](https://i.postimg.cc/76zz18KK/Quattro-in-car.jpg)
No mate, sure it said somewhere on that notice they would swap out when stocks are available etc ...@Mafia_GF Did you arrange that direct with Victron?
Hey at least its not pitched lol.. you could have your lunch on there and be sure you'll not fall off.. Are you going to make a start today ?The days to be spent on the roof, here's a picture from 8:15 this morning.
Yes, installing the frames today/tomorrow, will leave the panels off as not sure when the electrcians are coming and I don't want the open MC4 plugs getting damp - they want the panels left disconnected so they can test them individually.Are you going to make a start today ?
You could put the pannels on ready mate.. what I did was to use some sandwich bags with na elastic band to seal off .. yes i know I am mad but it works RonYes, installing the frames today/tomorrow, will leave the panels off as not sure when the electrcians are coming and I don't want the open MC4 plugs getting damp.
Just take a photo of your unit's serial number and attach the Victron notice and email it to them. Then follow up with a call to confirm receipt..@Mafia_GF Thanks, I'll contact my supplier.
I had thought of that, but they sometimes collect water, but under the panels they should be OK, but they are going to have to lift of the panels to do the cabling anyway.You could put the pannels on ready mate.. what I did was to use some sandwich bags with na elastic band to seal off .. yes i know I am mad but it works Ron
Ooh - what size is that Ronski?? I've got an 8.5m x 4.5m flat roof on our garden room that is currently barren of solar panels.....!The days to be spent on the roof, here's a picture from 8:15 this morning.
Be interested to know how many panels / what size that is.
Started thinking about mounting on the flat roof too, but hurt my head too much trying to work out how I'd fit angled panels without shading each other....
Ah yes, apologies - I remember reading that!Its 6 meters top to bottom, 5.85 meters left to right in the above picture, and I can get 12 panels on there - see first post in this thread.
It depends on whether the panels can all face one direction, that would save shading each other, how you fix them is also a consideration, if the roof sub structure is strong enough you can use a ballasted system - concrete blocks or paving slabs holds the frame in place.
@katie279 Yes that 4.5m width makes it a bit awkward, but I'm sure some could be squeezed on there one way or another.
