6500xt would have worked![]()
"worked" is a strong word to use when using it on PCI-E 3.0..
"worked" is a strong word to use when using it on PCI-E 3.0..![]()
Have you guys who are struggling with old motherboards tried the UBU bios updater, linked a few pages back?
Nope, happy to give it a go though!
Does RTX 3050 actually do anything at all on the above systems? No? Then a 6500XT will boot and give GTX 970 performance. Ergo, it is a far far cheaper option than spending £300 to find another £300 is needed for your `budget` purchase to actually be useable.
Therefore, yes a 6500XT would have been a far far better `working` option.
Whats your overclock. wanna get ready for when i recieve mineIt should let you upgrade individual components of the bios, including the CPU microcode. Fingers crossed
Just topped the Time Spy Extreme RTX 3050 list with my overclock
Thanks again @Gibbo
Could be that the cards are DOA or there is a setting that needs altering but I'm sure if the 3050 just wasn't supported on older systems then there would be a bit of noise on the internet about it.
Use the OC Scan function so it can work it out itself. Mine comes back with +176mhz GPU and +200mhz Memory. (without touching voltages)Whats your overclock. wanna get ready for when i recieve mine![]()
Agree entirely.An even better option would have been "leave it as it is" since a 6500xt would have barely been an upgrade over his 1650s on PCIE 4.0, never mind on a PCIE 2.0 system!
Have you tried forcing the motherboard to pcie X8 mode?.Nah, the card itself is fine, it works perfectly in my B550 motherboard (and my 6800 works fine in his).
@Gibbo
Was wondering about the Palit warranty Gibbo. A Google mentions it being upgraded from 2 to 3 years, back in 2018.
Does this apply to the UK?
For those that had issues, I wi be curious to know if you are able to get it working.
I’ve an old gigabyte G77-d3h motherboard. It sounds like it might not work. It would be a shame. It would make it easier to piecemeal upgrade
Ours is working fine now with the new parts. Much better all round tbh
