Permabanned
Can i call my AIB's MANAGER is next stagenext big thing on the internet omg nvidia nerfed the clock speed on my card to make up for bad caps and bad board design how dare you nvidia! Change.org petition income for sure.
AMD says allot then REALITY kicks inWell Amd says that there gpu will have 50% more performance with less power and might beat ampere and probably use less power compared to ampere. Hope this is true. If so, Nvidia will fail badly and will get a big slap on the face by Amd.
Nv gave AMD free "card" to get some people cause cant buy em 3xxx cards anywaypeople who want your money can say pretty much anything
Why cant they just raise the power limit. Increasing the power limit will reduce the fluctuation by a lot since thats the problem.
They have and it has raised the TGP by another 10w. Whether you care about that or not is up to you.
Yep, it was a weak attempt to spin their lack of stock into something good I think.EVGA are going to look like clowns after trying to dunk on everyone else thinking they 'solved' the issue with a different cap configuration.
Well except for one small detail:If you are getting an OC over the boost of 1710Mhz that what the box says then surely your return varies as per all over launhces were some cards are better than others?
Small DETAIL was said that NV is keeping BEST SILICONE for FE cards...Well except for one small detail:
The 3080 FE cards boosted to close to 2000MHz. Not the 'spec' 1710MHz.
TPU had them around 1900MHz mostly:
https://www.techpowerup.com/review/nvidia-geforce-rtx-3080-founders-edition/32.html
CB also had them at up to 1965MHz:
https://www.computerbase.de/2020-09/geforce-rtx-3080-test/2/#abschnitt_die_taktraten_unter_last
If a driver would have 'fixed' this by limiting boost to 1710MHz, then all the reviews would have become invalid.
And then a 3080 limited to 1710MHz versus an overclocked 2080Ti... well, that wouldn't look good at all.
