so after reading this thread it seems to me that
The 4070 is over priced
4070 has the relative performance of the 6800XT at all resolutions
4070 has the relative performance of the 3080 at 1080p/1440p but a bit slower at 4K
Has less VRAM than a 6800XT
Costs about the same as a 6800XT for MSRP models now
California has a law on energy consumption in pre-builts which is great to know living in the UK
other bits that don't matter: die size; cuda core count; The bus size; PCB size.
Probably other things but the only thing that does matter is price to performance.
AMD have a chance to stick it to Jenson but probably won't.
Pretty much it, just add that its a 4060/4060Ti dressed up as a 4070 and thats about it. Priced like a 4060 it would sell in droves.
Pretty much it, just add that its a 4060/4060Ti dressed up as a 4070 and thats about it. Priced like a 4060 it would sell in droves (priced like a 4060Ti would also still likely sell in droves), priced as it is then not so much.
Is it though? while the 1060 matched the 980 & the 2060 matched the 1080 but the 3060 only matched the 2070, was behind the 2070 super and didn't match the 1080ti. So the 4070 only matching the 3080 lines up with the previous generation improvement in terms of performance. This is why only price to performance maters. The actual number on the card is irrelevant.
The shader count is the whole reason the RTX 4070 has unimpressive performance, because it's unchanged from the RTX 3070.other bits that don't matter: die size; cuda core count; The bus size; PCB size.
The shader count is the whole reason the performance of the RTX 4070 has unimpressive performance, because it's unchanged from the RTX 3070.
They're charging you more for a card with the same core count and fewer ROPs, which seems a bit presumptuous.
I’m surprised no one has done a comparison of the 4070 and 3070 clock for clock to see how see how the architectures differ.That isn't necessarily relevant depending on how different or not the architecture is mind - theoretically efficiency improvements in the pipeline could even see less shaders at the same clock speed produce faster results.
I guess they'll be looking at GPUs as "gaming" tools just like companies say that the huge profits were due to gaming, not mining. If you catch my driftCalifornia seems to be interested and they didn't allow power usage to come down naturally they wrote a report and passed a law about it.
"• Aggregate energy demand places gaming among the top plug loads in California, with gaming representing one-fifth of the state’s total miscellaneous residential energy use.
• Market structure changes could substantially affect statewide energy use; energy demand could rise by 114 percent by 2021 under intensified desktop gaming...
• Energy efficiency opportunities are substantial, about 50 percent on a per-system basis for personal computers"
R&D is spread across multiple products. Is not like the professional cards don't benefit from gaming R&D at all and those have, most likely, huge margins.You can't ignore development costs.
A game costs pennies to print onto a disc or host for download on a server. They still cost a fortune in man hours to develop and design, hence why they cost ~£50
I'm definitely not saying Nvidia aren't taking us to the cleaners, but only thinking about material costs is wrong.
As it was pointed out if your only concern is power usage then don't plug it in.You wrote, "That your insistence on using "power usage" is what everyone has taken issue with assumedly because it's not only technically incorrect to describe it that way but it's also highly misleading."
Sorry that you don't understand the simple concept that when you plug an electrical item into an electrical socket and switch it on that it uses electrical power.
True but then how would you even go about factoring in R&D costs for a single product, do you include all R&D cost since the company was formed, do you include all the IP they've used, do you include things that at first glance don't seem relevant but were necessary to enable the R&D of something else, do you factor in the value of any IP that came from that R&D.You can't ignore development costs.
Υes, yes, yes and yes. That's what ive been trying to say for 50 pages but I was branded as an nvidia defender. Who cares what the margins are, lol. All that should matter for the end consumer is performance price and power draw.other bits that don't matter: die size; cuda core count; The bus size; PCB size.
It is not a 4060 or a 4060ti.Pretty much it, just add that its a 4060/4060Ti dressed up as a 4070 and thats about it. Priced like a 4060 it would sell in droves (priced like a 4060Ti would also still likely sell in droves), priced as it is then not so much.
Kind of raises the question of why it took you 50 pages when three words would've done it.Υes, yes, yes and yes. That's what ive been trying to say for 50 pages but I was branded as an nvidia defender. Who cares what the margins are, lol. All that should matter for the end consumer is performance price and power draw.
In general, there is not, and there never was an xx80 chip. Each generation used a different die, different % compared to the full die, different memory bus etcetera. Going by the DIE used, the 4070ti uses the xx104 die, same as the 2080 did, same as the 1080 did, the 980 did etcera. So sure it is. Even going by performance, it's slightly slower than the 7900xt (around 8-11%), so it should at least match the 7800xt, just like last gen the 3080 matched the 6800xt, right? So sure, it's really a 4080 I guess.just wondering was the 4070ti really 4080 12gb or Nvidia just being kind ?
