- 30 Oct 2014
Just taken my G10 of my Vega 64 to put some new heatsinks on the vrm's so i'll do a quick run through of what i did. Apologies for the poor quality pic's.
Make a template on the back of the gpu by locating the four screw heads.
Use the template to mark your new holes on the backplate and bracket. Use a center punch or a nail like i did on the marks and drill the new holes, i used a 3.2mm drill bit.
I had to make the holes slightly oval to get the bolts in flush to the back plate.
I cut down an old heatsink i had to the required sizes for the vrm's. Not sure if it's necessary to put heatsinks on the chokes?
Attach G10 braket and aio.
And enjoy your new lower temps.
Not sure why but my temps are up 3c on both core and HBM since before
Oh and if your having a go, be carefull not to void your warranty or break your gpu
