You need to apply a lot of pressure I think, how much of a gap do you have between the IHS and the PCB?
Jokester
Jokester
Next to no gap. Will the pressure of my freezer pro not be enough? Pretty sure i have made an arse of it anywayJokester said:You need to apply a lot of pressure I think, how much of a gap do you have between the IHS and the PCB?
Jokester
sgoaty said:Next to no gap. Will the pressure of my freezer pro not be enough? Pretty sure i have made an arse of it anyway
This is another one lol Im going to take it off again and have a look. What do you think to using a ShinEtsu thermal pad good idea, bad idea?Jokester said:Should do I would have thought, was this the one that was hot? Maybe the IHS isn't flat or something. There's not that much TIM on the inside to be honest.
Jokester
sgoaty said:This is another one lol Im going to take it off again and have a look. What do you think to using a ShinEtsu thermal pad good idea, bad idea?
Jokester said:Are you using a cold plate between the TEC and IHS?
Jokester
Cyanide said:I will be when I re-assemble it all tomorrow
Jokester said:I used to use liquid tape over the top of small chips next to the core but as far as I can tell it not necessary. If you've got a cold plate then it might drop you temps a degree or two or more if you're lucky as the IHS is just more metal in the way between the chip and the cooler.
Jokester
toucam said:Has anyone used Scythe Ninja with IHS taken off? I'm interested in taking IHS off as my temps are crap but not really sure if it fits without IHS and requires heavy modification.
Phnom_Penh said:Cache chip?
