MG42Maniac said:Mine would not boot into windows @ 2.8GHz with 1.45V. Have I reached the limit of my chip?
jadeskye said:my san diego does 2.7 at stock volts, up to 2.9 at 1.41 and 3ghz at 1.45 but i', scared to push it farther....
Fred said:Pushed the FSB up to 255 taking me to 2804.7
I've increased the voltage to 1.4 in the bios, however cpu-z is still showing it at 1.344v so it doesn't seem to have taken effect.
Seems to be stable so far, SuperPi finished ok, just running it through Prime atm.
Highest temp so far is 46, so lookin good
Soul Rider said:Make sure you disable cool and quiet in the bios, or that will underclock your chip. Also, do you happen to have an ASROCK Dual Sata? I have a similar problem with mine not seeming to actually put any more than 1.360 Volts through the chip, according to CPU-z.
young lad said:
MG42Maniac said:Hi,
I dunno if this usually happens but for some strange reasons my PC seems to have underclocked itself back to its orginal speed. I was running a 3700+ @ 2.6Ghz which I primmed for 8.5 hours without errors now for some unknown reason its back to 2.2GHz. I am 100% sure I did not accidentally touch something in the BIOS as i've not been in there since my Overclock. Does this sort of thing usually happen or is something wrong?
Thanks
