Was that Dual Prime? (1xSmall FFTs and 1x Large FFTs)Soul Rider said:Ran prime stable for 10hrs, but crashed after 1/2 when playing quake 3
I thought prime was the ultimate stability test? How the hell can a machine be prime stable for 10hrs, then get beaten up by a silly little game like Quake3?
Soul Rider said:Ok, Were moving on slowly.
I'm taking this one step at a time, trying to get the machine stable before taking up a level.
Currently @ 11*238 2618Mhz.
Before Big.wayne jumps in about no screenies... 2.6Ghz is not a particuarly pleasing clock. If I hit 2.7Ghz or above, then i'll post screens, when it's worth showing off..
Looks like anything over 2772Mhz requires a lot more volts as going from 2717Mhz to 2772 requires 0.075V extra which is a lot for 55Mhz CPU speed.Street said:2717MHz - 247x11 @ 1.425V
2772MHz - 252x11 @ 1.5V
helpimcrap said:sounds like memory problems. have you run memtest?
Dutch Guy said:Looks like anything over 2772Mhz requires a lot more volts as going from 2717Mhz to 2772 requires 0.075V extra which is a lot for 55Mhz CPU speed.
ted34 said:When i first got my 3700 it ran 12hrs prime95 at 3.1ghz at 1.55v. Then after reinstalling it wasnt stable and had to back it down to 3ghz at 1.54v. This was all on air. Still the best single core clocker i've ever had
What cooler + fan and stepingted34 said:When i first got my 3700 it ran 12hrs prime95 at 3.1ghz at 1.55v. Then after reinstalling it wasnt stable and had to back it down to 3ghz at 1.54v. This was all on air. Still the best single core clocker i've ever had
Disco_stoo said:I clocked mine to 2640 (fSB 240 x 11) and tried it out in 3d mark 05, and got a lower CPU score than it running at standards speeds. No issues or anything and it's a stable 40 degrees, any ideas why would it be slower?
