Another UK shop is replacing boards from their own stock cant name.
I assume it isn't the one who's name sounds like the hardware device you use to transfer documents etc to your computer, as some folks remarked earlier that they were not playing ball in that respect.
For those of you who bought the older revision motherboards. Don't panic. If you want to swap out your board for the new B3 revision, please contact your motherboard manufacturer who will issue you with an easy and simple swap.
If you don't want to RMA your motherboard to the manufacturer, you can contact our CS and we can either issue you credit, or a swap to the new B3 all via our RMA department.
Can someone (preferably OCuk staff) please confirm the information from this post (click me!) is correct and applies to the P8P67 Deluxe?
In other words, if I don't use the light blue ports (or ever plan to) then there's no *need* for me to replace my P8P67 Deluxe?
Thanks.
i went to the shop yesterday with my b2 asus p8p67 pro was there 10 mins and left with a new b3 board, i did have an RMA open with ocuk though
thanks for the swap out link i've filled my form in , dunno what to put in the notes box so i just typed none ( if you leave it empty it does not let you proceed )
I put in a request for an advance replacement!
So is anyone else not bothering sending theirs back then? Don't think I'm gonna bother personally, I see the risk from taking it all to bits and back together greater than the risk of every having a problem from the current motherboard seeing as I don't use the affected ports.
