Second Build - University
i have been playing BF3 and ive got some temps and stuff for those interested
these values are all MAX at LOAD
i am playing at 1080p with everything on ULTRA settings, but NO AA
i had AA on, but i was getting a pink flickering which was rather annoying, it was a playable FPS, but annoying so i turned it off
i am running the 10.10 drivers, i dont like testing beta drivers - rather stick to the stable releases
CPU @ stock:
30 degrees idle, 62 degrees load, 24 degrees ambient
5850 @ stock:
42 degrees idle, 70 degrees load, 24 degrees ambient
on other news:
- I have been in talks with Crucial who are willing to send me a review sample when they receive back the current ones out on review :D
- I have been in talks with Gainward who are willing to discuss a 2012 sponsorship deal :D
- i have been in talks with Zotac who i am in discussions with about Sponsorship :D
over the next week i will be doing:
- remove the H50 and replace with the D-14
- remove the rear exhaust and replace with 140mm roof exhaust
- replace the stock window with the custom one i made
i have got to say this is a great looking build, in fact you are using a lot of similar parts to my current build (h50, psu, ram, hdds), i think the main difference is that case (i got a storm enforcer)
but anyways this is a great looking case, i am loving the white bladed gts and the white black contrasts, looks great :)
did you get the temp information you wanted for the push/pull comparing stock to gt's? :)
BIG UPDATE:
right then, today i thought i would do a number of things:
1) remove the faulty H50 and replace it with my spare D-14 (which would also lower temps)
2) replace the rear exhaust 120mm with a white LED 140mm roof exhaust (which would allow me to use my custom side panel)
so i got to work, this is her when i first started
remove the TV card (which doesnt pick up BBC channels) and the gfx card
leaving a nice void
unplugging everything
a lot of dust considering it was only built for 2/3 weeks!
removing everything
starting to remove the faulty H50
out of the case
Mrs Mobo after the cooler was removed
taking off the H50 backplate was a PITA! i resorted to gouging it off with scissors VERY carefully :)
all cleaned up
starting to assemble the D-14, first with the backplate
almost finished with the mounting
ready to put her back into the case
can you see what ive done wrong?
see it now? :p
yep - i mounted the cooler the wrong way around!
back off -> cleaned with IPA -> fresh bit of MX4 -> reseated the correct way round :p
can you see the MAJOR issue now?
guess what?! the graphics card doesnt fit under the D-14!
i had two options:
1) buy a cheaper, worse performing cooler, refit the 5850 and then replace with the GTX 580 when it comes
2) keep with the D-14, but a proper ATX mobo, which will fit the D-14 and the GTX 580 and it even does SLI and Gen 3 PCIe
i went with option 2, more expensive, but better in my view
also: ive just broken 2000 views :D
that is 2057 views in 71 days ~ 30 views/day :D
looks nice m8 :D did you not try the gentle typhoons on the nh-d14 first?
i thought about that but there are two issues:
1) they use a plastic clip to hold the wire restraint, i didnt want to break them trying to take them out
2) i have two 120mm typhoons, the 140mm centre d-14 fan wire clip wouldnt have it
i *might* respray the d-14 fans if i decide the d-14 is permanent :)
Another LARGE update:
my motherboard was meant to come yesterday when i booked a whole day free and whatcha know - City-Link did there usually performance of delivering it today when i had a very full day!
yeah, i know, DHD is a lot better :rolleyes::rolleyes:
right then, lets get to the nitty-gritty of it becuase i know all you like to look at is the pictures and scroll over me blabbing on about nonsense :p
when i unwrapped her
WOO! PCI 3 - might come in useful with the 580 that will be coming later this month :D
more box art
the good stuff
close ups for you
new type of socket protector - very useful actually :)
OH YEAH!
starting to disassemble the old mobo, starting with the cooler
side by side comparison: z68-gd65-z3 and h67-e45
the d-14 backplate was rather close to the msi heatsink screw
i fitted the custom window as well
her all finished up :)
