Before you call sky you need to rule out it being an internal issue as if it was a sky issue I would expect to see a high noise margin.
Chances are the socket might not be near where the router currently is. You need to look for a socket which has a removable, detachable bottom to it which can be unscrewed.
Like this:
Unscrew the bottom and connect the router (with filter) directly to that.
While were discussing filters, make sure you have one on EVERY device which is connected to you're phone line.
Im sure its not a problem with his line, he has 41db, you need to call.
Your proborly just set on the wrong speed, they should be able to bump the speed up easily.
what exchange are you on? Type your postcode or phone number into this and tell us what exchange![]()
You need to phone sky broadband help desk, they will turn up your speed from their end, obviously this is limited by your phone connection, however you should get much more than 2000kbps.
I then run the TC IP optimiser to change your PC settings, remembering to create a restore point first.
I had the same problem an I now get 15,323 kbps.
p.s. If you can get this sorted in less than 15 mins on the phone to SKY I will be surprised! I suggest you make a cup of tea before your call.
Ahh, none of the sockets in my room have two parts to them
one thing i should add is that im using the sagem router, the dark grey one, heard about another kind that are not so good, which do you have
edit i see you have netgear one
I suggest you look outside of your roomcould be behind something etc.
Is the socket wired to something else?
I'm using a netgear one, the white, sky broadband one.
If he had a high noise margin on the downstream sync then yes he would need to call sky but as he only has 6.2 its an issue with his internal wiring which sky can't help with. Once he has resolved the wiring issues he might have to then call sky but he needs to get that noise margin up / find out the cause of it.
I just asked my dad and he says that I am connected to a master socket and that there are two other ones in my parents bedroom and my brothers bedroom. :S
That's not the case with SKY they cap the max you can receive for some reason, either way a phonecall will be required.
Okay, find your master socket, are the phone lines overhead or underground?
If overhead, trace the cable back to the master socket.
Edit, i dont think you can have more than one master socket.
One of those sockets will be the master and will feed all of the others.
Check the other sockets to make sure they don't look like the one I posted, if they don't and your sure there is not one elsewhere its possible you might have an older style master socket but check the others first.
My noise margin is 13.1 db down and 17.5 db up
It that case it sounds like you've been capped.
Can you copy the other details and post it here?
