Is there any way to force sync at a lower SNR than 6 or does fibre not work like that?
It doesn't work like that, I think the DSLAM ignores any attempt to tweak the connection from your end.
Does the engineer absolutely need access to the master socket for a fibre installation?
I ask because our master socket is behind loads of boxing, so it's a major job to get to it.
The socket in the front room is actually an extension from the master socket, with a master socket faceplate on it, would that be usable?
Thanks, I figured as much, looks like I'll be waiting until I move before getting involved with fibre. Ah well!Yes they do - your speed will suffer if they don't isolate all the extension wiring.
Do Sky normally have access to newly enabled areas from the beginning or do BT have exclusivity for a while?
My area is due to be upgraded in September but I'd rather stick with Sky than switch to BT Infinity.
It's nothing to do with BT having exclusivity. Because of the way they provide FTTC, Sky (and TalkTalk) have to order a GEA Cablelink from Openreach at each Fibre enabled exchange to be able to deliver FTTC services from it and in some exchanges they take longer to do this than at others. As soon as they have this link in place you will be able to order.
Extra question for bonus points, between the combo of the Openreach modem and my RT-N66U (with Merlin FW), is there any way to obtain line stats?
