Does the latest firmware not have MER support?
Instructions: http://www.forum.draytek.co.uk/viewtopic.php?f=2&t=17819&start=15#p74398
Discussion, you might need to contact Draytek: http://www.skyuser.co.uk/forum/sky-router/48839-draytek-2820n-sky-fibre-unlimited.html
Did you follow the instructions?
Depends how fast the wireless is connecting at...
Press Option and click the Airport icon in the menu bar. It's the transmit rate.
Draytek support sent me a link with Beta firmware and instructions, will have a bash tonight![]()
Just had my sky installed this morning. Is there any way to find out what the real sync speed is? Im guessing the value reported by the sky router is actually real?
Also, I know that the line needs to test to find out what is stable, how long does that last for? It seems to be dropping out at an ever decreasing time frame, and then when it does, it also disconnects me from the wifi connection as well (odd)!
Is it later than 3.3.7.3? I've got a 2820n I can't use at the moment.
