Anyone got a Fibre line some instructions would be handy too
Thanks
Thanks
Instructions...?
1. Connect to wireless.
2. Use Internet.
Sorry the Draytek I currently have was a pain to get working, I just pop the extracted username and password in and off I go!
I'm getting Sky Fibre this Friday and will be looking to get my 2820n working with it - what did you have to do to get it working? When i moved to O2 i had all kinds of trouble guessing what the access mode, encap. etc was!
Sounds like you might not get as good a connection as an engineer install but there isn't really any info yet.
Anything I should know re the self install or indeed FTTC in general?
Does the Draytek allow you to put a DHCP Client ID in on the WAN2 setup page? If so you need to extract your Sky username and password from the Hub and put it in to that box and it should then work.
seem to be a number of "green boxes" popping up round my local area. Exchange is due to be enabled this month according to various websites so fingers crossed for some fibre soon!
