Sky Fibre Optic
Well I spoke too soon, woke up this morning to no internet
Router is offically dead, it lasted 2 days
Sky are sending a new one out, in the 14 months of being with them, this will be the 4th new router.
Is it possible for us to buy our own router with this?
This problem with cheap/bad routers is putting me off from ordering SKY's service.
I cannot afford to have no internet, due to a bad router and would happily buy my own from elsewhere.
IP profile = ?
I think you mean this from the router page?
Modem
Modem Status
Connected
DownStream Connection Speed
39992 kbps
UpStream Connection Speed
2000 kbps
I cant use the BT link you gave me it wont work so is that what you mean? Still stuck at 20meg literally on the dot aswell so its defo capping of some sort as its to near 20 meg to be a problem anywhere else.
Trying this I cannot get mine to connect. Got the Sky Router back on temporarily.
Updated my Linksys E4200 with Tomato and cannot get it to connect yet. I changed the settings it says to, but it wont connect just times out with DNS error on Chrome. Will give it another shot in a minute.
Does the -c option go in the same box as the -x? It seems to imply they are different but does anyone know?
Well I cannot seem to get it working. Tried connecting it with different cables to the modem, tried -c and -x in that same box, and tried on the WAN and a LAN port, to no avail. I just connected them together for now and disabled the wireless on the sky router. Hopefully that also helps with its lifespan problem. This'll do for now TBH. I'll keep trying though.
You don't NEED the Sky router for install (Openreach engineer brings VDSL modem) but I'm not sure if they can test fully without it.
/Edit: New router is a lot better for wireless than the old one (I had very old school one)
/edit2: yes its wireless n
I can trust them
YAY for wireless N :D...would still rather ethernet but until my parents let me do this, this can work :D
Earlier replies shows you need option 61 for DHCP, unless you can do that with the 4200 you're SOL.
Oh and the obligatory speedtest from earlier today, well yesterday now, I guess!)
Was estimated at 31Mbps on BTs site so thoroughly pleased. No drop in speed at all so far.
Is there a gigabit wireless N router compatable with Sky Fibre?
Why would you need one? Even 80mbps won't saturate a 10/100 connection.
If you want gigabit between your PC's for file sharing, save the head ache and get a gigabit switch.
I had mine installed this morning, BTO engineer was a great chap, arrived at 8am sharp, he'd already done the bits at the cab, and the new faceplate was fitted by 8.10. He then checked the line and wasn't happy with it, the max attainable rate was about 30mbps, so he decided to replace the whole telephone line from the pole to the master socket, winner! Now synced at the full 39992/2000 :) The engineer eventually left just after 10.
Unfortunately I have the ECI openreach modem which isn't (easily) hackable, so I can't find out what my max attainable speed is now :(
Just hoping Sky will roll out 40/10 pretty soon now, not worried about 80/20 just yet.
Mines ordered, installation date set for the 21st May.
I just hope I'll be as happy on fibre as I've been on copper as in nearly 4 years of being with them I've never once had to call CS and I'm still using the same router.
BT engineer confirmed im at 40 meg and 2 meg up at the master socket but the sky router is capping me at 20 meg, no idea why, perhaps a dodgy batch but another router is being sent out.
