You rock! thanks for the help![]()
Welcome, if you need anything else answering/testing feel free to shout
still waiting then, new fibre cab is there though which is a good sign
My ping times are shocking and the speeds are all over the place according to speedtest.net
Should I be waiting for 10 days to see if it all settles down?
Is this a new installation?
Are you using SKY router or your own router?
What's with the 7800n love?
New install today and I have put my billion 7800n on instead of the sky router
Have you tried using the sky router and running the speed test?
Better than the supplied Sky unit?
I don't dispute it but in what way?![]()
Gigabit LAN would be nice but I'm buying a cheap switch for that.
That's what I did.
I bought TP Link 8 port Gigabit router for around £30.
Something is definitely wrong.
If you call SKY they are likely to tell you to wait 10 days. Whether or not this will cure the problem is not clear.
If I were you, I would keep the SKY router attached for the next 10 days, so that when you call them and begin trouble shooting, they will go through different settings on their router.
The moment you tell them that you are using your own router, they are likely to tell you that this is the reason why your internet connection is malfunctioning.
My pings are near identical to what they were on day1, compared with now. Nothing changed within the first 10 days.
I can only suggest that you wait 10 days before raising a ticket with SKY.
