Yep, would just put the price of the subscription up if they got booted off.
Sky F1 HD is an average 18mbit ... so that would be 36mbit on 1080p.
It eats enough of my disk space as it stands. I don't relish the idea of it eating 25% of my drive for a race recording...
So just to check about Eco mode... am I right in thinking that overnight it goes into deep sleep state (and any Sky+ remote recordings sent from website/iPhone won't get through), but in the morning it will wake itself up into the normal standby state where it can receive Sky+ remote recordings.
What are the times when it goes to deep sleep and then wakes up to normal standby? And will a recording sent when the box is in deep sleep be queued and then delivered when the box goes into normal standby, or does it get lost?
We will forever disagree on this and I am not in a position where I can provide all the evidence to support my side. Simply put, it is a software change within the latest firmware update and not hardware.
As for HDMI being a set standard, sorry but you really haven't got all the facts there.
HDMI has had several revisions since it was first set. I believe that Sky's Sky+ HD STBs were first created before v1.3 was published (22nd June 2006). Source: Wikipedia.
Dolby TrueHD was a part of the 1.3 standard. 3D over HDMI is a 1.4 standard. This was published on 28th May 2009.
Remember that it takes time to design and build the STBs. As such, the components would have been sourced long before the respective Sky+ HD STBs were produced.
Maybe Freeview can broadcast 1080p video quality. So too can the Satellite broadcasters. Both Freesat and Sky use the same group of satellites, so whilst you may be watching BBC1 HD on Sky, your neighbour will be watching the same transmission of BBC1 HD on their Freesat HD STB.
However neither Freeview, Freesat or Sky currently have any of the channels working at 1080p.
Finally, did you know that during the Olympics that the BBC Olympic HD channels were broadcast using a higher quality image than normal for their transmissions? This caused no end of problems for the Humax Foxsat HD STBs. This was resolved with an emergency update during the first week of the Olympics.
...And will a recording sent when the box is in deep sleep be queued and then delivered when the box goes into normal standby, or does it get lost?
Why would you want sky to convert the interlaced signal? Any screen can only display a progressive image so your TV will do it.
If you have decent equipment connected to the end of the chain (and it has not been a signal that sky has had to scale as they are awful at this) this will do an admirable job of processing the interlaced signal![]()
Mine won't update, even when forced, quite annoying.
Mine is 4f31 or a drx890, I'm stuck on 11p, that table states the DR stream is updating to 15p currently?
Freeview broadcasts 1080p right now at this very moment, albeit it 25 FPS. It dynamically changes between 1080i50 and 1080p25 depending on the type of content being broadcast, so interlaced for sport and progressive for drama, etc.
Just checked, mine is a DRX890 (version 4f31d5) running R005.053.70.11p
That is completely correct.
The instructions for performing the update manually are in the same post, just under the table.
For information, there wasn't too many changes between 11P and 15P. A few issues were fixed for 12P and an attempt to rectify the 'Denon Issue' was made in 15P.
The 'Denon Issue' has now been fixed with the latest firmware, which many of those affected received as a beta during the test period. This is documented on the Sky forums.
I never said anything of the sort.
F1 HD is broadcast in 1080i at an average 18mbit. I'm well aware of the capabilities of my Panny plasma and home cinema setup thanks.
Oh, and welcome to OcUK.![]()
