- 4 Aug 2007
- Wilds of suffolk
6.87kwh today
93.5kwh now MTD and just 24 short of target
Think cloud has descended onto the welsh mountains, don't think we getting much solar today![]()
lucky for me, currently it looks like the only bad day for the rest of January. But we know how quick that can change lolYup 8kwh yesterday but I think that'll be it now, quite heavy overcast in East Anglia, so doubt I'll generating anything today. Doesn't look like it going to get any better for the rest of the week either.
Still already over December, 74kwh Vs a running 86kwh so far.
i made 53p on the first session on the 19th......i used £1.32 of electric from the grid that entire day, so for me its not a bad saving of around 40% of the days grid use, just for 1hrs sufferance. Add to that i exported 8kwh of solar too @15p....Got yesterdays elec breakdown from Octopus, so I used 17kwh between 12:30 and 3:30 that would normally be zero
I tumble dried a load, ran the dishwasher, heated my upstairs with a small fan heater rather than the GFCH
So its all stuff that would have happened just moved into that slot.
Oh also ran the house from the grid at that point rather than battery
Battery went into todays go period on about 38% so I used around 2kwh more than I needed to in effect.
Based on the savings session being 1.5 hours I should in effect get 8.5 x £4 for that part, the 10 day average for the 4:30-6 I haven't worked out, but that would be around 2kwh since two weeks ago I was using grid and giving batteries a boost in that window.
I could be on for about £40 of points assuming the formula we are basing this on has been correctly interpreted.
If not the experiment has cost me about £7 since I am on 40p units with go outside the cheap period.
Profit hopefully around £33 (40-7)
I guess we will likely see Mondays results tomorrow and yesterdays on Friday. Could slip into next week.
Leccy used from grid £1.32
Saving session 53p
Solar exported £1.20
= +41p for me on the day
Gulp...we might be in trouble, my savingsessions app is showing 8 points for 24/01/23 session. It was updated 20 mins ago. I used approx 4 units in the -4 to -1 period before the session.
You sure, the points given on the 24th relate to the 19th session
| Hi Daniel, Thanks for being part of our Saving Session on 19th January. Here’s a quick look at the difference your efforts made: |
you used 17kwh in the space of 3 hours?
thats 5.6kwh / per hour!!!!
I am guessing plus background use but sounds insane, even with those things mentioned above running.
Indeed, sorry missed on battery charging which can pull 5.5kwh on its own
Ahhhhhh ok, that's seems a lot more realistic.
