Solar panel production figures
I'll be on the phone to the installers tomorrow.
Do I have a valid reason to be concerned?
Any pointers on things to raise with them?
Ir should I just call EPVS and see what they say?
Your best argument is really as per what Ron-Ski said, if you're clipping now, you'll be clipping way worse in the summer.
Even assuming your battery is starting at 0%, it won't take very long to fill up a 5.2kWh battery if you're hitting 3-5kW generation.
They've under-sized the inverter compared to the system, because they should really be doing a G99 with a larger inverter to allow more export capacity. G98 only applies if you're locking the whole thing to 3.6kW because it's auto-approved. G99 requires an application that can take a few months.
If it's maxing out now, then that's going to be a lot of lost generation in the summer, request an upgrade to 5kw inverter, only reason you have a 3.6kw is because the paperwork is easier. They can apply for G99 and change the inverter if approved.
I'm glad I did for for a larger inverter as a result (solis).
Now I just need to get the 5kW gen 2 GE... Though I see they do an all in one now which is 6kW....
If you have a thermostat it won't heat up already hot water. So you'd use less oil as it won't trigger the hot water to heat.
Ah well I bow to your greater knowledge...
We have a nest room stat, which obviously reaches desired room temp, but i didnt know tge water tank also has a stat. Ill have to look into that.
Sadly, it seems you're bang on.
Battery starts at 25%
They know we use 3500kWh a year and have the capacity to produce 6000. So obviously export capacity was part of the criteria
Most hot water tanks should have a thermostat else they'd just overheat/boil or never get to the target temperature.
If you don't have a hot water tank then I can't help you!
Clear skies here currently! Generation kicking off earlier and earlier! Almost at my baseline of about 260w already! Out most of the day so likely get a good chunk in the batteries!
Hit a new peak of 4.939kw today… awesome!
Nice you'll soon be part of the 5k club!
My highest peak to date.
It's possible but I don't have an EV, so I could be forced off it anytime as well.
Part of the calcs I guess, I hope gas and electric wholesale is down by then and we start seeing better deals coming in.
This Flux seems like a low-effort way of maintaining things whilst getting paid well for excess generation through to September-ish.
Interesting, Solcast is forecasting 6.8kWh tomorrow, forecast.solar is predicting 22kWh… might as well chuck a dart at a dartboard and sacrifice a goat for guidance from the gods.
