- 19 Oct 2010
Generated today 0 kwh
3.9 yesterday, 1.9 today so far, but it didnt start till 11:15
its right on the limit of what they can do apparently - was worried we'd end up with two less than quoted!Nice, that is less roof, more solar panels
Rained off?
nah delayed due to supply and @Siliconslave stealing my install slot
Hes got exactly the system there I am getting (same installer we guess due to location and same email on availability)
Just checking my Eleccy statement and just realised that my batteries have been charging from 12 each night since the beginning of the month when the system was upgraded. I now have 16kWh at 38p.
We do however the charge rate is 5kWh on the batteries so that 1/2 has amassed 16kWh so far! Do have 97kWh at cheap rate so does even out.no off peak rate?
Don’t think so, have a AlphaESS system and they did a update which seems to have played with settings which I hadn’t noticed, looks like they’ve got issues with starting and 1/4 hour intervals but it’s ok if you start on the hour. They have another update in a few days so they may have noticed this and it’s being fixed.Based on clocks changing?
We were pushed back by a few weeks as well, was supposed to be mid October but the inverters weren't innah delayed due to supply and @Siliconslave stealing my install slot
You aren't missing much, besides starting in December and the darkest days with the least sun hours will give you a good starting point for upside!
True but even a small generation and cheap eco7 battery charging takes some of the ££ off the final bill.
sorry to hear you're still not with us @Mercenary Keyboard Warrior - it'll be worth the wait, certainly after the cap rise again in April.
Almost £3 a day lost on not using batteries. 11kwh at (34-7.5 pence) = 11x 26.5 = £2.91
That is the only negative, but you could also be making/offsetting £'s on the money in the bank at 2.72%, so if your system is £12k, and you have that in the bank it's made you ~£27 in interest, at least offsetting some of that expense or lost saving.
Did you settle on the 2x 5.8kWh Solax packs btw?
