Isnt that Katies setup?
Seems that way.
Temperature is not much of a factor. Its 9am ours is producing 704w thats more than we are currently using in Electricity with 2 people working from home. So yep its working well and its not even doing much.
Thats good to know. thanksIf anything they work better when they are cold.
But usually cold weather= lower sun/sunlight.
If you could have end of June sunlight, and middle of December temperature it would be perfect
forecast is for clear blue sky all day today and tomorrow .....so hoping for double figures for the next two daysI still have snow on my panels. I'm sure Katie is sabotaging me.
Producing 2kw at 10am today.... Another good day!Isnt that Katies setup?
im on 1.9kwh now, but i upload manually later in the evening
dont know how to do it....im not as tech savvy as you guys, but as im now at 2.6kwh, some people might not be happy lolHipposLair is in relegation position, but fear not, the sun is shining.
It still irks me that people don't just do hourly updates, would make comparisons so much easier!
i thought we was doing it as kwh/kw....i'm running at 2.06kwh/kw at the moment compared to some in the team who are running at between 0.9 to 1.3 kwh/kwAlso I think for fairness, we should prorata the generated amounts to equalise everybody to a max 4kW of generation.
That way it isn’t the one with the biggest that is better, I’m sure that how normal life works out isn’t it…..
That's what I've been saying all along (but someone gives me some stick for that, but I can take it ), simply divide kWh you've generated by the Kw of panels, which gives kWh generated per Kw of panels.Also I think for fairness, we should prorata the generated amounts to equalise everybody to a max 4kW of generation.
Heheh, boys boys boys.... You'll never learn.That's what I've been saying all along (but someone gives me some stick for that, but I can take it ), simply divide kWh you've generated by the Kw of panels, which gives kWh generated per Kw of panels.
PS. 5.69kWh so far today with 4kw array
Well in that case, I want a latitude bonus then for being higher North!
Size matters is all I can say!
