Solar panels and battery - any real world reccomendations?
I think its probably inevitable that my Dec figure will be lower than a typical profile.
Yes you will see lower due to the clipping, but my point is, that its a bad solar December, you will do better when its a better/more typical solar December - its my second worse December in the six years I've had panels. My Decembers have ranged from 71 to 122, and that's entirely down to the weather.
552Wh today, bringing my December total to so far to 83.36kWh.
Dont think we will be producing anything today…which leaves me on 246.8kwhs for the 2 1/2 mths in 2022.
Its start on the solar road and saving us money along the way. 2023 will be a key year to see if its worth adding a small battery for usage when its cloudier, to lesson the draw from the grid long term. If i do get a battery, i will get tye stackable extendable kind and purchase them one at a time, maybe the pylontech variety
Dire indeed today. 0.5kw only
December as a whole was good. We achieved 444kw against last year's total which was 297kw.
As Tony Blair said "Things can only get better". Tomorrow is the first day when it is over a minute longer than the day before, plus the sun is starting to get higher.
0.15kWh today, total for December is 83.51kWh, total for year is 4630kWh, which is my best year so far in seven full years.
2022 Stats:
Meter - 4676.9kWh
MyEnergi CT - 4465.2kWh
Powerwall CT - 4.66MHh
Interesting that the MyEnergi CT is reporting lower...that's what HA uses to upload to PVOutput.
Could it be subtracting standby power used at night when the inverter isn't producing energy? I doubt the inverter uses that much power in a year while it's asleep though...
I have a Sense energy monitor which uses CTs and the solar production figures are lower than actual because it subtracts the negative readings from when the inverter is in standby.
They're also not 100% accurate - I've noticed that when I'm pulling lots of power from the grid overnight (e.g. when charging my car) the solar CT negative reading increases... probably induced voltage confusing the CT?
