- 25 Mar 2004
- Fareham
£12,295 with a 5.12kWh Sunsynk battery. I know it's a lot but I don't think prices are going down any time soon with inflation at 10%.
It's not the worst price I've seen but it's not the best either.
What is your usage like on electric kwh per day?
Is this your 1st quote or just the best one?
5 kwh is a pretty small battery and unless it has 100% DoD you won't get 5 kwh out of it.
As with all things it will essentially boil down to how efficiently you can use the system and how much it may save you in the long run.
Friend of mine is getting an install off the same people I used, less panels (5.6kwp in 14 panels) but it's a 5kw inverter with G99 application, and a 9.5kwh battery for around £12K, so it's still possible to get more for the same sort of cash as you're spending.
