Without just picking bits to reply to, the WiFi dongle does two things:
- AP Mode = Broadcasts it's own SSID (you can see it in WiFi networks on capable devices).
- STA Mode = Connects to your WiFi network to route data to GE.
The dongle also has an admin portal, as you've found out.
Assuming the dongle is working and all connected up OK then look at the following:
Get your dongle IP address and then just connect to it via a web browser. I can see my dongle is called
HF-A21 and is visible in my router connected devices, with a local IP address.
From my regular desktop machine I can just browse via Chrome to http:// followed by the dongle IP address, in my case
http://192.168.1.184. This prompts for the admin details.
Lock down AP mode
- Go to AP Interface Setting on the left.
- Change the Pass Phrase value to something else. I use the serial number of the Inverter for ease of remembrance. This is visible on the GE dashboard in various places. This is the password demanded if anything connects to it.
- Optionally mark the Network Name(SSID) as hidden. This will mean you can't see it to connect though without undoing this. Hidden network does not mean it's not broadcasting or make it secure, just an optional step you can do to improve security.
Lock down Admin
- Go to Device Management on the left.
- Change the Password field to something stronger than the probably insecure one that is set by default.
Security
Regarding this more specifically, it's actually worse than you think, because if someone has connected to your WiFi dongle, yes they can browse the internet probably very poorly. Being connected to this though, if they get into the dongle admin portal with the insecure password it came with, they can read your current WiFi password and SSID in plain text within the
STA Interface Setting page.
