- 4 Jul 2006
Got a chimney on roof that starts shading panels ~6pm, will take a while to get someone out to look at panels if one of them goes duff and in the mean time the rest wont generate. Failure rate is extremely low on them.I would only go with micro inverters if the panels were facing different directions or there was significant shading. Otherwise, you're adding multiple points of failure in hard to access locations.
Replacing a single main inverter is relatively quick and simple.
