3 strings on my 8kW inverter (Growatt MIN 8000 TL-X2 1ph) works well.
I'd say so.So the OcUK wisdom would be to up the inverter to ~8kW and pack as many extra panels as I can on the NW side of the roof? I'll see what the installers think - I know the DNO application paperwork has gone in already so they might not be too keen to change things at this stage but it is worth an ask.
Mine are at 120 degrees, so less north than yours.They predict an increase in production of ~2350kWh annually which seems conservative vs the numbers Ron-ski is expecting from his 12
those numbers are cray cray for NW panels, my SSE panels 10x440w is only estimated at 3680kwh/yrNo idea where you are in the country, but for roughly around Derby PVGIS reckons around 2850 kWh.
JRC Photovoltaic Geographical Information System (PVGIS) - European Commission
Photovoltaic Geographical Information System (PVGIS)re.jrc.ec.europa.eu
My 4.62kW of NW facing panels (137 degrees and 35 degree tilt) have beat the PVGIS prediction in every month since I got them installed in January aswell. Since installation from 10th January to the end of May, they should have produced 976kWh but have actually managed 1135kWh. That's on an annual prediction of 2794kWh and the weather has not been great either.
You're doing the right thing getting them put in at the same time. I didn't do this as I was told by pretty much everyone it wouldn't be worth it so ended up paying more when I finally got it done.
Next question buddy - how does one lock down the charger? I've seen you can set a pin on that hardware unit which must be entered at the start of each charging session... How does that work with octopus intelligent go?That’s the one
Don't forget to keep us updated, and if you can join the PV Output team - link below. Warning, it gets addictiveAh well, I'll take my newly-sized 12.76kW 8872kWh/yr SE/NW system and see if it does work out the way the thread suggests!
Don't forget to keep us updated, and if you can join the PV Output team - link below. Warning, it gets addictive![]()
I think this extra is a no-brainer, glad I asked here - thanks!![]()
Depending on the export rate, it may be better (certainly easier) to simply export it.how to dump excess solar power into my hot water tank once the batteries are full
