Option 1
REC 420W panels
SolarEdge 10kWh battery
SolarEdge Inverter
Option 2
Meyer Burger 385w panels
Enphase inverter
Enphase battery
They haven't gotten down into specific model numbers or anything
Just a nice little summary table and a bit of text
It does feel a bit expensive, but this is planning to be my long term house so perhaps taking the hit isn't that big of an issue.
A bit expensive is somewhat an statement, I'd be shopping around. The REC panels are meant to be good but they are expensive at £140 a piece. A 440W Jiko panel is £71 a piece. I'm not sure what the benefit of the Meyer Burger panels are, are expensive and have a lower output - not Chinese?
I'm all for spending money where it makes sense but only if it improves performance and the return on your investment. Hardly anyone puts solar on their house to make them feel good, its all about the economic benefits it brings. The more you spend on the system for the same performance, the less benefits you get so there is no logical sense in taking the hit. This is crucial when you are fitting a small system as you'll still incur a lot of the fixed costs of installation.
Below is the actual equipment costs for option 1, they'll be a lot of sundry costs on this (say at most another £1k of misc. equipment) and an installer will be getting some trade discount. If you add the below up you'll realise you are being charged over £5k for design, installation, scaffolding and warranty. Installation is a one day job for 4 people.
REC 420W panels 9X £117 = £1053
SolarEdge 9.7kWh battery = £4950
SolarEdge Inverter = £900
Solar Edge Optimiser = £465
If you just swapped out the Solar Edge edge kit for say GivEnergy, you'd save £2,800 alone a system with effectively the same performance. A GivEnergy 3.6kw or 5kw hybrid inverter plus 9.5kwh battery = £3500
The only reason I can see of going Solar Edge or Enphase is that you've got such a small number of panels on each side of your roof, it makes sizing an inverter tricky. Perhaps someone else can weigh in on that.
