Useful to be aware of.Just seen this, could be useful for anyone wanting solar.
If getting the energy companies to do the install, thoroughly check pricing as the "interest" maybe built into the price, if you get my drift.
Looks like fixed is best for us looking at the octopus tariff tweaks. Need to work out the optimal combo.Are folk generally on fixed outgoing or also with e.g. Agile outgoing for their export tariff? I'm looking back and really don't see the benefit that much, the price is rarely over 15p/kWh so isn't it usually better to just take the fixed 15p?
Phwoa even in winter? Check you out Mr electrons! I've got givenergy so I was considering doing intelligent flux in summer but for winter I'm not sure if I'll get value from the variable export tariffs. Tbh I don't know if I'll even be exporting until March: the battery just about covers my daily demand with a bit of a top up but I've not been getting anywhere near topped up as yet.Flux here
It's probably far from ideal in the winter, probably better options, but for me there could potentially be issues switching back come spring. With recent system upgrades it should only be November to February (Dec & Jan being the worst months) that I have to pay. October I was in profit, and so far this month, which has been terrible I've effectively paid 5.2p per unit.
Once we get a heat pump I will need to change for winter.
I was thinking being on Go with agile export could be quite good, its basically a play on peak rates. Import at 8.5p and export at 15-40p in the peak window. The flux import rate is just a bit too high in my eyes, no justification for it.
yep. i use this for my tariff. set and forgetEon Drive Next.
Not for summer, I wasn't thinking for summer. I used intelligent flux in summer and it was by far the most profitable tariff for me.Have you done any in-depth analysis on this? I looked at August's data and even if I could have captured all of my generation in my battery to export in the peak rate window, I would have been quite significantly worse off. The highest export value was 18.4p/kWh which just never offsets the weeks of data where the peaks don't beat the 15p of the fixed output.
As it happens, I can't store all of my generation in a given summer day so I'd be absolutely ruined by moving to Agile for export. I am also export limited to 5kW by my DNO so I can't pour the energy out fast enough to take advantage of the really peak times. It strikes me as really edge case where this works in favour of the customer.
Im contracted to 15p export until next december…..Rumours going round on fb that fixed 15p oct outgoing export is getting nerfed to a variable export with a floor. Someone got an email to say that and posted it. Anyone else get similar? I've just got the docs and applied for my export yesterday.
If that's the case, the floor could then be dropped next summer. Could be a pretty massive nerf tbh, basically like a slow move of everyone to agile export.
