1. This is the bandwidth that I use. You can see how it is made up....
Frame rate
Resolution
Bit rate
The three factors above will add up for each camera to give you the MB/s used and that will need to be less than the NVR can process as a maximum. Allow for expansion if possible or changes in your settings as needed.
2. Even though my NVR has POE ports (4) I preferred to use a Netgear POE switch and connect all of my cameras to that and then that to the NVR. That way the attached devices to the POE Switch are also available directly through my home network and not just via the NVR. Also, for me, I can remotely turn power on and off etc via the Netgear switch web interface for each camera if and as needed, for a reboot or working on the cable etc.
3 Posted by dmsims
4. No. Motion detection "marking" is useful to tag an event to a timeline but not solely for recording motion only. When it rains, and insects etc at night, you will have a zillion fragmented recordings. Also any intrusion event would need "context" around it.
5. Yeah it gets hot but I use a lockbox with two fans fitted bolted to the floor joists in the loft. Seems to keep it cool.
